Sponsored by: Innova
Adapter D2B -> fiber optic cable
Old Nov 29, 2006 | 01:29 PM
flave's Avatar
Hey guys,
i'm looking for this cable:
It's a normal D2B fiber optic cable to connect to the w203 c-sportcoupe bose amplifier, but the other end has a "normal fiber optic" connector.
Does anyone knows where i can get this?
thank you,
bose amp:
this adapter would be to use a different external audio source (not the audio 10 radio cd) ... do you guys think it will work?
thanks,
Old Nov 29, 2006 | 09:01 PM
SUNILP's Avatar
2015 E250D
No I do not think it will work since data also travels up and down those lines besides sound.
Old Nov 29, 2006 | 09:52 PM
flave's Avatar
for what i know the bose amp with the D2B has a signal input ... and a signal output.. in theory if i replaced the audio source of the signal input.. it would work =\ but .. lol
probably the best solution it's just switch to another amp...
Old Nov 30, 2006 | 07:16 AM
SUNILP's Avatar
2015 E250D
The entire system is a daisy chain system. Each device gets a input and output. If you break the chain, then all devices will stop working. So if you want to connect an aftermarket headunit to the output leg, you'll have a left over input leg not connected to anything and everything will turn off. Also, you cannot control a cd changer with an aftermarket unit.
