Telephone pre-wiring with hands-free facility - please define
AMG ML63, M3 CSL, Z4M Coupe, New Audi TT, Audi R8 (coming)
As the title suggests.
{p.s. I am in the UK, so perhaps I need a European owner to answer}
I am used to buying BMWs where I buy them pre-wired with the bluetooth module. All I then need to do (If I choose to) is buy the relevant cradle which connects my phone so that the aerial signal is boosted and the battery of my phone is recharged as I use it. But often as not, I don't bother buying a cradle (since I use several phones) and therefore just synch whichever phone I have with the car when I use it.
My question is, "what exactly have a bought in my new ML63 - is the option as described above merely a phone pre-wiring kit? i.e. without bluetooth module? And therefore what do I need to do to get my phone synched with the car and a handsfree capability up and running?
I suspect that this option has been a complete waste of money and I would be better getting a dealer to install a seperate handsfree kit in my car. Please tell me I'm wrong..
I just went thru it
Doctor D
I recently went through what you are. the prewiring only means the lines are run and depending on the model you have the buttons on the steering wheel and radio.
my dealer in the states needed an additional 2500.00 to convert my prewired car to a functional blue tooth..
good luck
Steve
good luck
Steve
Thanks very much Steve, at least now I know that I am effectively starting from scratch.
It's a poor show compared to BMW, where it only costs around £300 (i.e. $500) to include pre-wire and bluetooth on the spec sheet and then when the car is collected you can begin making phone calls straight-away..
it is cheaper if it is factory done
When I asked Mercedes why it costs so much, I was told it is much less expensive if factory installed, if it has to be done by the dealer it is 3-5 hours of labor, which we know is not cheap at mercedes. I hope it is a lot less in the UK..
It wasn't even an option for the factory to fit it. Within the BMW buying process they fit things like bluetooth and satnav at the distribution centre when they arrive in each country. The dealer doesn't get involved.
. there are several other options you can take such as the parrot, but they do not utilize the cars steering wheel or thru the radio.
good luck,, I went thru all of this and just gave up and had Mercedes install the HMI blue tooth unit
mCAR Bluetooth
Here is one only for $300 and it is better than the OEM as support streaming and speech: http://www.ebay.com/itm/271395945115
