Easiest Way to Add On Aux to W203
2002 C320 Wagon
I have a 2002 C320 w/the factory head unit. I would like know the easiest way to add on an auxilliary feature, without having to solder/hack up the tape unit (b/c I don't have the skills).
It has been suggested that as an alternative, the cheapest, easiest way is to add on a wired FM modulator via the antenna. However, I have learned that MB uses a different antenna plug.
Can someone please walk me throug how to add an auxilliary feature or install a wired FM modulator. Please cite what parts are needed and include photos if possible.
Thanks,
Alan
Thanks,
Alan
2006 C230SS & 2009 E350
did you check this out?
https://mbworld.org/forums/showthrea...od+integration
2002 C320 Wagon
Aux continued...
Unfortunately, the referenced aux install (did you check this out?
https://mbworld.org/forums/showth...od+integration) does not work on pre '05 models. Thanks for the input however.
The tape deck modification is an option, but not for unskilled hands. Other suggestions seem to be for a reasonable head unit upgrade to either the Audio 10 Becker 6021 (plug n play capable), or the Becker Monza (MP3 but no steering wheel controls and not fiber optic capable) with an auxilliary wiring harness available for about $20 more.
If anyone has other suggestions, please share them.
Regards.
Regards.
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
Thanks,
Alan
Thanks,
Alan
W203 slightly modified
Thanks,
Alan
Thanks,
Alan
Go nuts and install a navigation unit.
C200K Jul 2004
Does this kit you speak of work on the AUDIO 10 CD (Becker 6021)?
I have a 2004 C200K and want to add AUX for MP3 capability without using FM.
Many Thanks
