Activating a factory CD Changer
A Mercedes mechanic told me that it is not a simply "plug and play" process when installing a factory CD Changer because the head unit will not recognize the CD Changer until it is re-programmed.
Is this true? If so, is there anyway to re-program the head unit without taking it to a Mercedes Dealership.
The mechanic wanted over $200.00 to re-program the CD Changer.
Any help, guidance or assistance would be appreciated.
I'm confused!
I would like to find some definitive instructions on this so I can figure out if the problem is just a coding issue or a problem.
If any item on the bus is disconnected, or fails, or loses power, then the whole fibre ring stops working and the head unit can see nothing.
So, when your CD changer was removed, the bus was physically reconfigured and therefore just plugging in new CD changer wont work.
I suspect the 2 fibres from the CD changer go to behind the head unit where they are just sitting - you will need a D2B joiner and to carefully open up the head unit fibre plug, swop one fibre with one that goes to the CD changer and connect the one removed to the other one that is left. Theres some info (but no pictures yet) at www.mercupgrades.com in the D2B info document.
To be sure you got the right fibre connector, stick a torch at the CD changer end shining into the connector !
If its not by the head unit, it may go to by the phone unit.
Regards
Richard
Adding the CD changer should make it all work again. I say that because if the fibre loop hasnt been reconfigured (and it hasnt) then its unlikely that the head unit was re-coded ... (although, to be fair, it sounds like your car is set up with one loop around the car, rather than a load of pairs going back to head-unit (or some other meeting point)
BUT, without the CD changer powered up, with its wakeup cable, then it still wont work.
Of course it could have been removed because something wasnt working, Its worth remembering that the phone controllers do fail as-well, and either unit broken will cause problems.
The phone controller (on euro cars) is normally in the trunk on left hand side behind the panelling (i.e in the space between boot liner and fender)
Cheers
Richard
R
