Nokia 3110 Issues
I've got a beautiful '01 E55 AMG and it came with a rather old 3110 Nokia mobile phone. I bought myself another mobile number specifically for the car and I'm experiencing some problems with the setup in the car.
Whenever I make a call, the connection will happen and straight after I'll get a low battery warning from the phone and the phone will switch off even if the phone is plugged into the car in the armrest. Sometimes, however, the phone will work and you can actually make a call.
The battery itself doesn't seem to hold a charge, I tried removing the battery completely hooking up into the car, but the phone won't switch on, which I guess indicates that you need a proper battery hooked into phone at all times.
Hunting down batteries for a 3110 is a pain in the butt, to be honest. Is there a fix for my current problem or should I get M-Benz to update the phone system in the car?
Thanks.
http://www.batteriesplus.co.uk/acata...110__3810.html
If it was only the battery on the phone and you are happy with the two SIM setup, I would by a new battery. You should be able to upgrade to UHI on D2B and get a modern setup but it would be quite costly.
Perhaps you should check the car wiring to be sure that all connectors are OK.
