Sponsored by: Innova
Command upgrade install L.A.?
Old Feb 9, 2007 | 11:01 AM
inferno2469's Avatar
Does anyone know of someone reputable to do an install from a 2003 w211 non-command to a Command unit?? Preferably in or around los angeles??
Old Feb 9, 2007 | 12:02 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Do you have a comand already?
If not, just wait for Steve (MBenzNL)'s next trip back to Los Angeles. He makes frequent trips to LA for installs. If you want to check his website, it's www.mbenznl.com.
Search through the forums for MBenzNL and you'll see how much he has done for the MBWorld community.
Old Feb 9, 2007 | 12:20 PM
yes i was hoping for that, but i didnt see any info on when he might be back out here.
Old Feb 9, 2007 | 12:58 PM
drexappeal's Avatar
He usually has a Spring, summer, and fall/winter trip.
Old Feb 9, 2007 | 02:52 PM
smb7420's Avatar
E500
Buddy, it's VERY easy to do yourself. It requires you to remove..about 5 screws and 5 plugs.
Buy yourself a Torx 20 key(to remove the screws) and do it if you're up for it.
Ask some MB dealers to do it for you - some will, it's easy money for a job that they'll charge min. a half hour of labor for.
Here's a link on how to...https://mbworld.org/forums/e-class-w211/152101-success-upgraded-euro-comand-instr.html
just remember that the ashtray plug isn't pulled out like the others, you just slide it down.
I really urge you to save money and time by doing it yourself.
Old Feb 9, 2007 | 04:05 PM
Here's a link on how to...https://mbworld.org/forums/showthread.php?t=152101
kool! i thought i read on the forums that going from a NON command car to install Command was a pain in the a$$ and wires had to be run and a whole slew of other things.
Old Feb 9, 2007 | 04:22 PM
smb7420's Avatar
E500
Nope, it's plug and play.
If you're going to a Euro comand, dvd in motion cant be enabled on 06+ versions as they need to be version coded by the mercedes star computer - dealers wont do it for you(illegal) so you'll have to dish out around 200-300 bucks to mbdoctor or MBNL(Steve) to have it done
but dealers can enable the Mp3 playback on it.
after installing the comand you may get a battery error in your MFD(steering wheel display), drive around for about 10 min and it'll go away. It just needs to recharge up.
Old Feb 10, 2007 | 12:42 PM
murman's Avatar
S213 2020 E450 4Matic CDN Spec 07/19 build
I may be wrong, but it MIGHT be a problem depending on what you original equipment you are replacing.
I think it's a problem if you're replacing an Audio 20 unit, but not a problem if you're replacing an Audio 50 unit.
Old Feb 10, 2007 | 01:41 PM
uh, sorry pardon my ignorance, but which is the audio 20/50? i have the one with the cassette player\harmon kardon speakers.
Old Feb 10, 2007 | 01:54 PM
murman's Avatar
You have Audio 50, so COMAND swap should be a cake walk.
Old Feb 10, 2007 | 02:00 PM
THANK YOU, Thanks you!! i am back to being excited again.
Old Feb 10, 2007 | 02:37 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
(SHOULD BE) as long as its Pre wired...Most 03s are Not pre wired for nav.
Old Feb 10, 2007 | 04:34 PM
ok, i am just interested in the command unit, not nav. do i HAVE to get the nav or can i just upgrade to the command from my audio50? i just want to be able to have ipod/bluetooth integration.
Old Feb 12, 2007 | 06:51 PM
BlackCard's Avatar
CLS55 AMG
I'm about to put my 2006 CLS55 Command on Ebay (US Model). PM me if your interested. It is in great working condition, just swaped out for Euro.
Old Feb 13, 2007 | 10:47 AM
murman's Avatar
You've got PM.
