Automatic shutdown of Comand
If you find a Fibre optic toggle you can disable the MOST connection when the car is shut off this will stop the radio from shutting off, but it will drain your battery if you forget to turn it off, and messs with your Audio if you forget to re-enable the Bus when you turn the car back on.
You car is D2B, so all you need to do is to install a toggle in your D2B wake-up wire and it will have the same function.
The powerdown feature comes over the network not for the radio itself.
Thanks, but thats a lot of work.
