Sponsored by: Innova
iPod Integration on 05 C55
Old Mar 12, 2007 | 06:55 PM
C55LA's Avatar
Getting a 05 C55 soon, want to know if there is an iPod Integration kit? Where to buy and if there is any good instruction I can find online (I tried to search on this forum but not much help) Any help appreciated.
Old Mar 12, 2007 | 08:11 PM
lxl_Jeffro_lxl's Avatar
1987 E300 TD
Originally Posted by sawloo
I setup the AUX input in my'05 for connecting directly to my ipod. The sound quality is great, much much better than those FM Transmitter :v I think it is worth to post the instruction and some pictures here since many people have asked me how to do it. The installation is very simple, everything is pre-wired(not sure if it is the same for pre'05). It took me less than an hour to complete. Thanks to cc4469 and JeT, this would not be possible without their information
1. You have to get the cable harness (A 203 540 61 07) from a MB dealer. I paid US$44 from a dealer here in Northern CA.
2. Remove the right front door sill, the A-pillar, and locate the pre-wired connector.
3. There is a little circle inside the glove compartment. Push it with pressure, it can be pop out easily.
4. The hole is for fitting the AUX-plug of the cable harness.
5. Remove the plastic cover on the right outside the glove compartment.
6. Put the AUX-plug into the hole and wire the cable.
7. Wire the cable on the wall below the glove box and connect it to the pre-wired connector.
8. Active the AUX Input (by passing the CDC button for couple of second), connect the AUX-Plug and test it with your ipod or some audio input.
9. If it works, put everything back together and you are done!
10. You may now want to buy a wireless remote to control your ipod. So, you can select the music freely inside the car
Search the Audio & Electronics a little harder! Shouldn't be much different I'm assuming.
Old Mar 12, 2007 | 09:17 PM
NORTH 44 C63's Avatar
EuroCharged 2012 C63 BS Coupè
https://mbworld.org/forums/c32-amg-c55-amg-w203/113444-ipod-integration-kit-installed-c55.html
pay attention to post #17 from BENZMODZ with this link:
http://phdwebsite.powerpulse.cc/COMA...oval%20WIS.pdf
for step by step command removal
PS: the integration kit and Aux install posted above are 2 different animals
Old Mar 13, 2007 | 03:36 PM
edtv82's Avatar
From: dayton ohio hopefully it will be some place warm and sunny when i finish med school
2002 C32 AMG silver & 2003 Lancer Evolution 8 black very moded
DO YOU KNOW IF THAT WILL WORK ON A 2002 C32 AMG?
Old Mar 14, 2007 | 06:13 PM
C55LA's Avatar
Same for iPod Integration?
If I already have the AUX connector, is it that I just change that with the iPod integration plug? Do anyone know what is the item number for the iPod Kit in US?
Old Mar 14, 2007 | 06:27 PM
B 67 82 4213 (part # is international)
completely separate from AUX plug and 100% better sound quality, not to mention steering wheel control and HU display
Old Mar 14, 2007 | 06:28 PM
C55LA's Avatar
Smile North 44....thank you.. did you install yours?
Which would be a good instruction on installing that? I used to drive BMW and frankly, on mods... It is WAY easier to find info on them than MB.. can you please help me out? Thank you
Old Mar 14, 2007 | 08:35 PM
if you look at my post earlier there is a link to the command removal Step by step. The Ipod kit is plug and play from there. No I didn't do my own. Had a cellphone installer friend do it and I'm glad I did. Worth the $100
