Sponsored by: Innova
Blackberry 8703e Bluetooth
Old Mar 17, 2007 | 07:09 PM
KB5's Avatar
KB5
Has anyone been able to get good functionality using the Blackberry 8703e with the MHI Bluetooth Interface Module with 2006 Command? Also, does anyone know if the car's antenna is used or is the Blackberry's antenna used?
Old Mar 18, 2007 | 10:07 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Can't answer the compatibility question concerning that Blackberry model from personal experience - if it was listed as "approved" on the AWS site, it should work. If not, you take your chances. A post below indicates that it is approved. https://mbworld.org/forums/audio-electronics/183899-mb-bluetooth-w-blackberry-pearl-8800-a.html
A little use of the search tool would have answered the question on the antenna as well. In the U.S. MHI cellular setup, unless your device can be inserted into a cradle made specifically to connect it to the car's external antenna, it uses the cellular device's antenna, with the attendant reduction in connectivity. There are several such cradles made, marketed by AWS and by SmoothTalker. The websites and representatives for those companies should be able to answer questions concerning your specific device.
In the European UHI setup, information is downloaded via Bluetooth from the phone's SIM card, and cell equipment built into the car is then used - including the car's antenna.
In the U.S., you have the MHI setup unless your car was specifically modified, or you brought a Euro spec car over.
http://www.wireless4mb.com/
http://www.smoothtalker.com/products..._bt_blkbry.php
Old Mar 18, 2007 | 11:03 PM
KB5's Avatar
KB5
Thanks Skylaw. Much appreciated.
