Sponsored by: Innova
Need Help & Advise Phone systems
Old Mar 26, 2007 | 10:22 PM
Fastfish's Avatar
2003 ML500,06 C230 Sport
I have a question about getting a blue-tooth module so as to not have to use the Mercedes Benz selected phones what are my options I know there has to be a better way.
Thanx in Advance Fastfish
Old Mar 27, 2007 | 05:55 PM
hecdog's Avatar
2014 E350 Estate Wagon 4Matic
You have a couple options, one of them is OEM and a few of us are trying it right now. There's also an aftermarket solution which may or may not be yet available for your car.
Visit this thread for more info:
https://mbworld.org/forums/e-class-w211/184452-sick-waiting-argos-can-someone-confirm-these-part-s-oem-bluetooth.html
Old Mar 28, 2007 | 10:19 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
If you already have an MB phone system in your car, you're in luck. It should already have the Autosense PSE and V60 cradle. All you need is the V60 puck from AWS (https://www.wireless4mb.com/) and a compatible phone (which you do not have to purchase from AWS). See http://www.benzworld.org/forums/show...26#post2222126 for compatibility issues. AWS should be able to tell you when you order the puck if your phone and firmware combination are "approved" and will work with it; if you are told they are not "approved" then search the forums for contributors' success (or lack thereof) with different phones, and be aware that both physical equipment and firmware versions can cause problems.
If you do not already have a phone installation, you will need the equipment and procedures in the phone bulletin for your car. See http://home.earthlink.net/~phdwebsit..._bulletins.htm
Old Mar 29, 2007 | 12:35 AM
Fastfish's Avatar
Its in the Details
As is always the case the details kill the deal,it appears that both my rides are lacking equipment the ML is lacking the wiring up to the center console(pre-wiring) the C has the wiring in the center console/armrest but does not have the cradle I would truly like to get both up & working but I think the cost will be prohibitive on the ML.
Old Mar 29, 2007 | 08:03 AM
carpersn's Avatar
2019 Volvo XC90 Magic/Amber, '95 E320 Cabriolet Midnight,'14 GL350 Lunar/Almond was '07 GL320CDI
Try Ebay parts as you will probably find some for the ML since it is already mostly wired...
