Anyone heard of the Powerdriver PD-2
It says it can:
The PowerDriver PD2 two channel Bose Interface allows you to add an amp and a subwoofer to an existing Bose System, using our CableLink Harness for your particular car. The harness will keep the installation clean and simple (no cutting). The 35 Hz Bass EQ is fully adjustable from 0 to +10dB and the outputs adjustable from a decrease of -8 to a gain of +10 dB.
The PowerDriver PD2 also provides you with a versatile line preamplifier for adapting and interfacing to a wide variety of auto sound electronic products, and solves a number of related problems often encountered in more sophisticated installations.
Use it in any car stereo system to increase or decrease the level to your amps. This makes for a much better signal to noise ratio, and decreases distortion in any system.
Has anyone used it or something similar. If so, can you reply w/ the product and your luck w/ it.
