Sponsored by: Innova
W203 and COMAND
Old Oct 4, 2002 | 05:58 PM
amiras's Avatar
11' E-350 BlueTec
Question W203 and COMAND
Hi guys! I was wondering if someone can help me. I want to get a COMAND for my C230 Coupe and I'm a little confused about the one that will fit in my car. Is the 2.5 European? Or 2.0?
It'll be nice to have TV and navigation but I'm not sure if I need any additional equipment for that (antenna, TV tuner, etc.)
Any help would be appreciated!
Old Oct 4, 2002 | 06:27 PM
Richard's Avatar
2004 SL55, 2015 A250d, 2016 GLC250d
Re: W203 and COMAND
You need to get one from a C class - the part number will start with A 203 as a result .. Its COMAND 2.0 with the curvy front on it (rather than the square one)
Ive done a [not yet complete] document on retrofitting, its very easy on the US cars if you have teleaid (since antennas is there)
Adding TV is more complicated, because Im not sure if your US rear windscreen has the aerials buitl in ot nor, and adding the wiring loom is a major job ..
Nav is built into COMAND ..
R
Old Oct 7, 2002 | 12:05 PM
amiras's Avatar
11' E-350 BlueTec
Thanks Richard!
Regarding the NAV, do I need to install some kind of antenna or something?? Or it's built into the COMAND?
Thanks again.
Old Oct 7, 2002 | 01:11 PM
Richard's Avatar
Thanks Richard!
Thanks again.
If your car has teleaid, it is already installed - you may need the splitter so the gps aerial can be used by both, but I know on a C sedan the wire was already there etc behind the radio.
If I were you id check behind the radio and see what extra connectors are there
R
Old Oct 7, 2002 | 02:08 PM
amiras's Avatar
11' E-350 BlueTec
Well I don't have TeleAid but when I installed my Audio 10 I saw a couple of other cables back there (like fiber optic I think).
If you can tell me how the should look like I'll remove my HU and check them.
Going back to the antenna, since I don't have TeleAid, should I get the COMAND with the GPS antenna? What else do I need?
I saw an old post from you saying that you have a draft document with instructions....if that's the case do you think it'll be useful for me?
Thanks for your patience with a newbie like me!
Old Oct 7, 2002 | 03:16 PM
Richard's Avatar
Hi amiras
PM me your email, i'll send you the doc.
There will be some fibre optics back there, thats the prewiring that runs down to the space for the phone controller in the trunk.
You are looking for a coax lead with a square grey connector (called a HRS) on it- thats the GPS antenna
And, there may be a thinner coax lead, with a very small metal connector on it (thats the diverse aerial feed for the Audio-30 and COMAND)
R
Old Oct 7, 2002 | 03:43 PM
amiras's Avatar
11' E-350 BlueTec
Richard: you mailbox seems to be full so I'm sending you my email address here: ....
Thanks!
Old Oct 7, 2002 | 10:03 PM
evian's Avatar
M Benz
Hi Richard, I tried to pm you but it said that your mailbox is full.
I have a W203 without command system. I would like to have the Mercedes Command in it. So what do I have to get, and where can I get them?
How much?
Thk You
Old Oct 8, 2002 | 12:43 AM
peet's Avatar
09 C63
Please include me in that DOC as well.
Peet
Old Oct 20, 2002 | 07:37 AM
C230Ken's Avatar
Richard,
I would like to get the document also.
I have a '02 W203 with teleaid - would adding the command system just be a matter of getting the new hu and dropping it in the dash?? - is the connector that went to the radio the same for the command, would there be any extra clips or mounting brackets necessary to hold it in place??
Basically what I'm asking is - is it just a plug-and-play install?
Thanks,
Ken
Old Oct 20, 2002 | 11:43 AM
Richard's Avatar
Its not quite plug and play, you need to make an adapter
loom.
PM me your email, i'll send you the document.
I'll also try tidy it up and put it put for all to see
R
Originally posted by C230Ken
Richard,
Thanks,
Ken
Old Oct 22, 2002 | 07:46 AM
C230Ken's Avatar
Richard,
Did you get my pm with my email???
Old Oct 29, 2002 | 06:17 PM
levelr123g's Avatar
richard post it.
