Sponsored by: Innova
Commands for Voice Control
Old Oct 8, 2002 | 04:13 PM
mittalv's Avatar
2014 GL450
Hello All,
I do not have the Voice Activation manual from Mercedes for my S430 (W220) and so I two quick questions
1. To dial manually using voice I say "dial number", at the end, how do I make the phone dial the number once it is input
2. How do I add a new voice entry or delete an existing entry from the voice phonebook. The center COMAND screen has correctly replicated from my Timeport, but the voice phonebook did not.
Thanks in advance.
Regards,
Vikram
Old Oct 8, 2002 | 04:15 PM
awiner's Avatar
2003 CL55 AMG
Hit the VR stalk and say HELP ... The system will then give you all the categories you can get commands for. So if you want help for the phone, say HELP PHONE. The VR system repeats back all the valid commands.
now to answer your questions:
1. To dial manually using voice I say "dial number", at the end, how do I make the phone dial the number once it is input ?
You need to say "DIAL" after you say your numbers.
You need to say "Store Name" and then follow the voice prompts.
Old Oct 9, 2002 | 03:36 AM
Richard's Avatar
2004 SL55, 2015 A250d, 2016 GLC250d
After you have said the number you say "store" rather than "dial" when storing numbers. (you say dial, after entering a number that you are dialing of course)
R
