Sponsored by: Innova
navigation wont grab gps position
Old Sep 19, 2007 | 02:08 PM
pazuzzu's Avatar
2003 clk55
i have a 2003 clk55 and my navigation has always been flaky. sometimes it has gps coordinates and works great, but other times it never connects to a satellite and has no clue where it is. manually entering in the position helps but isn't ideal....especially if you're lost.
i never really use it so i never really cared. just before it went into extended warranty i had them look at it at the dealership. in typical mercedes fashion they just replaced the entire comand unit.
it's still flaky and i'm planning a long road trip...is there anyway to force it to re-sync with a satellite? this morning on the way to work it knew exactly its position, & had the gps coordinates. after listening to the radio for the commute i checked it at work and it had no idea where it was. it wasnt even on a road. i never turned off the car, it had just lost itself on a 30 minute commute...
i'm assuming there is something wrong with the satellite receiver since they replaced the entire dash unit and it didn't affect the problem. any ideas? as little as i use it i was hoping there was something i just didnt know or was doing wrong...
Old Sep 19, 2007 | 06:11 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
It is likely either the antenna, or the wiring to it. They are known for sometimes getting water inside the cable, causing the kind of problem you describe.
Old Sep 25, 2007 | 07:43 PM
pazuzzu's Avatar
2003 clk55
i just got back from my trip and i wanted to destroy my comand system. it worked flawlessly literally until i got lost. then it lost the signal, said sat 0, and thought we were in a different state.
oh well, thanks for the advice. i'm taking it in to get serviced.
