Sponsored by: Innova
2000 s class comand 2.5 S.O.L for A/V
Old Nov 6, 2002 | 12:26 PM
awesomedre's Avatar
s500
Question 2000 s class comand 2.5 S.O.L for A/V
hello,after looking at numerous posts and replies i am still puzzled.exactly what kind of AV/input if any can be hooked up to a 2000 s class comand 2.5?i went to nav-tv and they claim to have something fo dealers only.what i am trying to do is get at least one AV/input from my command 2.5 2000 s class and run that one input to a AV selector in which i could switch from multiple sources and display them on my navi monitor.can anyone sled some light on this matter?
Old Nov 7, 2002 | 05:22 AM
cone's Avatar
2013 SL 350, ML 350 BT
Re: 2000 s class comand 2.5 S.O.L for A/V
It is very easy.Your tv tuner, that is located at the boot in the left side, has 2 a/v inputs. AV1 for composite video (Most used) and AV2 for super-video. You need to buy a cable adaptor for connect your av source to your tv tuner. If you want to see your av source in your comand´s screen, select tv, go to av1 in the tv menu, and then you will watch your av source.
You can find your cable adaptor in this page:
https://ssl.kundenserver.de/s2495036...cht.shopscript
Old Nov 7, 2002 | 03:36 PM
Ted Baldwin's Avatar
300ce
.............This information is only correct for post 2000 S-class. The 2000 S-class in the USA does not have video functionality.
Ted
Old Nov 8, 2002 | 11:10 AM
awesomedre's Avatar
s500
can i put the 2001 comand in my car
Old Nov 8, 2002 | 12:37 PM
300ce
yes
Old Nov 8, 2002 | 02:52 PM
awesomedre's Avatar
s500
Thanks,im am very pleased to here that.Is the 2001 comand unit expensive and is it hard to install?Is the indash unit itself the only thing that needs to be swapped out or is their other components?
