Sponsored by: Innova
Noise when using Ipod Charger
Old Dec 22, 2007 | 10:57 AM
MAmendola's Avatar
2014 ML350 Bluetec, 2016 GLC 300, 2023 Corvette, Z51 Stingray
I have an IPOD and use the Aux inpt to listen to music. I have the IPOD car charger but when I plug it in and use the IPOD I get a low whine through the speakers. If I disconnect the charger the noise goes away.
Any information would be greatly appreciated.
Mark
Old Dec 22, 2007 | 01:23 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
It is likely alternator whine transmitted through your cigarette lighter. The sources of such a whine can be numerous, but a common one is inadequate grounding of the engine to the chassis (often because of corroded grounding straps).
Old Dec 22, 2007 | 04:34 PM
rockwool's Avatar
W123 200T -86
If it's corrosion then sand the area where the grounding is and use some copper paste when you're remounting the grounding strap to the chassis.
Old Dec 23, 2007 | 11:35 PM
MAmendola's Avatar
Thanks for the input. I will check the ground and any evidence of Corrosion but the car is new. Although, the main ground fron the engine to the chassie may be loose.
Have a great holiday.
Mark
Old Dec 24, 2007 | 10:56 AM
ToonArmy's Avatar
2003 SL500
I had a horrible hum on mine from day one. I think it is a ground loop problem in the MB audio system. Try a ground loop isolator (Radio Shack sells one, there may be other sources)
Old Dec 25, 2007 | 03:30 PM
Skylaw's Avatar
ToonArmy,
Thanks for your additional suggestion. A line isolation transformer (ground loop isolator) could help. His problem doesn't occur unless he is charging the iPod, so I don't believe it's a radio grounding problem as much as chassis. But, despite their bulk and (possibly) having to make a number of connections, to adapt the 3.5mm stereo plugs used on the iPod and the Aux input, to the RCA jacks commonly used on the transformers, it could work.
