Audio suggestions for my C32
The present system is stock, with COMAND. I don't want to change out the head unit. I'm fine with the highs in the car, but I'm looking for improved low-end sound.
Also, I'd like to keep the weight down and keep the spare tire compartment usable.
I have the following:
JL 500/1 amp
JL 300/4 amp
JL W6 10" sub
JL Cleansweep
What type of enclosure should I use for the sub? Should I change out the interior speakers? Do I need the 300/4 amp? How do I make use of the Cleansweep? Any other suggestions?
JL 500/1 amp
JL 300/4 amp
JL W6 10" sub
JL Cleansweep
All you really need is some door speakers, as the 500/1 can hit your W6 perfectly. I suggest Focals or Boston Accoustic speakers for your mids and tweets. They will match well with your 300/4.
I also suggest a bass knob so you can adjust your bass output in realtime ($40)
As for enclosure, I've had both - ported and closed. A well tuned ported box will be louder.
As for the box, I've been told that a sealed box will yield less boomy bass, which is fine with me. The size of the box is a concern as well.
Good call on the bass knob though, I think the Cleansweep comes with one.
