Sponsored by: Innova
command upgrade problem
Old Dec 23, 2007 | 03:09 PM
jpablo78's Avatar
MERCEDES SLK
Angry command upgrade problem
I have the following problem:
I have an SLK R171 with the dvd at the back. Two days ago i upgrade the navigator from 3.0 to 5.0 without problem. After this i try to upgrade to 6.0, and after 45 minutes, the process was still at half. Then i extract the DVD and i have an fatal error in the navigator. I power off the car and put my version 5 and all was ok. But now when i put a different version from 5, the command tells me that there is no DVD. Please help me.
Old Dec 23, 2007 | 05:14 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
It sounds as if you have a Euro spec car; if that's the case, I can't help. But if you tell us with certainty the model year of your car, and your geographic location - at least the continent - someone experienced with your model and nav system can probably help.
Old Dec 26, 2007 | 09:45 PM
jbondox's Avatar
beater with a heater
Skylaw, that's no fun, I like the guessing game... it was mr Green, in the library with the candl...
Old Dec 27, 2007 | 07:11 AM
XJ9's Avatar
XJ9
C350
I have seen this happen before but on a different model: I believe that the fix was that system required reflashing via DAS followed by the nav update. looks like you might need to schedule a visit to service.
