Sponsored by: Innova
EPC (Severe) error
Old Dec 28, 2007 | 09:21 AM
smiddyboy1's Avatar
w203 cdi
EPC (Severe) error
Hi ,
I've had the EPC program for quite a while, although I uninstalled it to clean up the pc,
Now when i try to re-Install it i get a pop up box with "Severe", has anyone found how to get round ths or what is causing it.
I found this part in the instructions
You MUST un-install all other EPC's first. Otherwise when starting the
install program, you will get a 'Severe' error stating 'Incompatible
Program Found'. Run the uninstall program from your old EPC. If it is not
listed in 'Add/Remove Programs', you may need to search for a program
named 'BHUNINST.EXE' on your old EPC install disc
But i cant seem to find the uninstall program, has anyone else has this problem.
