Sponsored by: Innova
help: cd changer to 2.0 comand
Old Feb 10, 2008 | 11:55 PM
youngblood's Avatar
i have a 98 e430 and i am retrofitting a comand 2.0 unit. i bought a fiber obtic cdc that came with a short orange connector cable that has 2 connectors cdc in and cdc out. does anyone know what cable i need to run from this cable to the comand. if so can you send me a picture of it and parts number if you have it. thanks in advance.
Old Feb 11, 2008 | 01:59 AM
Diesel Benz's Avatar
You are talking about the fibre cables from the CDC. Those are supposed to be used to make a fibre ring with your D2B (MOST) devices. If you do not have any other fibre device in the car, then both go directly to the Comand. Does you Comand have a D2B interface?
The changer would need wake-up, ground and power too but you don't need to wire these from Comand.
Old Feb 15, 2008 | 11:13 PM
youngblood's Avatar
cdc
i believe it has the d2b interface but i am not sure. how does it look? i have an adapter to connect a dvd or rear camera. i don't have any other d2b devices. how do i connect the cdc in and out to the comand? when i pulled the cover off i didn't see a terminal connector to snap it on the pin. i heard it need to connect to c1 pin 5 and 6
Old Feb 16, 2008 | 02:54 AM
husk323's Avatar
Tesla Roadster Sport
there should be a seperate fiber optic connector on the back of the comand, you can plug the cable directly into the back of the comand.
Old Feb 16, 2008 | 01:15 PM
SUNILP's Avatar
2015 E250D
Since your car is a pre-d2b model, you will have to run the necessary fiber cables to the trunk. 2 fiber cables from comand to trunk. You should have an existing harness in the trunk for the older changer that goes to the older radio. You can use 3 of these wires to power the changer. You will need wakeup, ground (locally) and power (constant usually from changer)
Make sure you get the correct rear bracket and wood panel also.
