Help! Removing the radio removal keys...
I'm using the official MB keys and have inserted them properly into the two slots at the bottom. They clicked and I was able to easily take out the radio. However, I now can't remove the keys. Is there a knack to removing them? They seem 'locked' into place. Do I push up/down/left/right - maybe the secret really is in the wrist action...
David
It does seemed locked in though. Believe me, I have tried every permutation of push/pull/twist/wiggle.
Maybe I used the wrong keys - here's what I have:
http://www.mellowman.co.uk/mbradiokeys.JPG
David
Which way did you put them in (cannot think of them locking in if put the wrong side towards the side.
The round end should release the radio by pressing the "spring" towards the radio and then get locked at the small cut. Perhaps the spring has been pressed and been bent so that you don't have enough clearance to press the spring to release it. Couldn't you use a small flat screwdriver from the side where it locks to release it (if it does not release when pressing from the side)
I had to remove the radio from the car to get a good look at why I couldn't get the keys out. The spring clips that the removal keys lock into were very, very stiff and as you suggested, needed a screwdriver to push them in whilst extracting the keys - job done.
I also decided to take out my ACC unit above the radio and dismantle it to correct the fading LCD display. Once everything was tightened and cleaned it seems to have cured the fading display - for now at least.
My next task is to decipher the third-party installed video/PlayStation2 system, for which there's no documentation or accessories...I'll no doubt require assistance on that as well...
David
try it and find out. if you are the type that likes to do their own thing no problem... just don't be like the one guy on here and send his girl up to the dealership when he screwed it up...
