Bluetooth and Laptop - (Not Phone)
I however, cannot seem to do this. I have bluetooth active in the car. I have the laptop set to discoverable. I have tested bluetooth from one laptop to another -just to make sure it can be found...
But the car doesn't find it.
Wouldn't this be the easiest way to transfer MP3's and contact lists for those of us whose bluetooth phones the MB doesn't support?
I keep reading others that say they've succeeded - any clues as to how? Anyone with experience using a macbookpro and their Mercedes Bluetooth - greatly appreciated ( 2007 C 350)
What are you after with the laptop BT connection? You cannot do a lot more than sending visitor cards to the local phone book at the car (if it has one).
If I remember right, the BT device name in my car is something UHI-related, I guess the UHI controller actually takes care of the BT connection instead of the Comand (this is different from the BT interface device that appears as "MB telephone" for me).
My bt on the laptop only finds one device to pair to - which is the MB Headset. I have been able to successfully pair to this device (from the laptop side only) - the laptop says "connected" but the car says "authorization failed".
I then viewed the vcards in another application to make sure all the data was there - phone numbers, addresses, etc. All look good.
I put the PCMCIA card into the Mercedes - went to Phone, Phone List, Import External Data from Memory Card - it imported.
I look and now have all my contacts in the Mercedes. However, no phone numbers. Just all the names.
Does anyone know what I've done incorrectly?
Sounds like you are trying to connect to the wrong BT device (as I explained earlier).
Edited: I realised you actually have a W204. That may be different from what I'm used to. You probably aren't using any BT phone adapter.
