NEW! iPhone adapter from Mercedes announced!
Full article and mercedes press release http://www.gizmodo.com.au/2008/06/me..._cradle-2.html
I'm also questioning that it will only work with the first version of the phone. If it's running the iPhone 2.0 software I would think that it communicates exactly the same via the dock connector as the 3G version.
He had no idea whether the cradle could be fitted to earlier models using a Bluetooth puck and either the Apple/MB iPod kit or a Gateway 500. Right now, to the best of my understanding, by using a Gateway 500 and a Bluetooth puck with in my '05 W220, I can use both the music playback and the phone capabilities of the iPhone, and switch between the two with steering wheel controls.
My only caveat is that while he had all the MB charts and installation diagrams and data, he did not truly seem to understand the iPhone - so I pass this on to be taken with a grain of salt.
With regard to the cradle not working with the iPhone 3G, the issue is not with the software, rather it has to do with the new shape of the iPhone. The current cradle will only "fit" the first generation phone, and thus iPhone
3G users unfortunately will have to wait until a retrofit is created to accomodate the new exterior. As far as software, the iPhone 3G pairs perfectly with the bluetooth puck. At least that won't be an issue as we all wait for the cradle...
Hope this clears things up a bit...
FYI, VIN # for car is WDBUF56J86A768629. I take delivery tomorrow assuming it passes an accident inspection at the mechanic.
See https://mbworld.org/forums/showthrea...77#post2788377 for the basics of the equipment you will need (but be sure to have the dealer check the phone bulletin for your car for exact part numbers) for the phone portion of the iPhone; and you would need the MB iPod kit or something like the Dension Gateway 500 for the music portion.
If your car didn't have the "prewired" option, you would also need the harness; the dealer should be able to look this up for you.
My understanding of the iPhone cradle (which is limited) is that the iPod connector will plug into it (which is why I hold out a hope that something like the Gateway 500 will work with it), and the phone portion will simply work through the car's Bluetooth system. But I have never seen one, or even anything definitive in writing, so don't take that as "gospel."
Frankly, contributors have reported success using the iPhone simply by plugging it into the MB/Apple iPod connector or a Gateway 500 for music, and pairing it with their installed Bluetooth system. No cradle is necessary, and the iPod kit charges it. I also understand that the iPhone can be answered or calls placed by using the steering wheel controls while it is playing music (as long as it is not in "airplane" mode) with this setup, in '06 and earlier cars. I am told that the iPod cable connections in the '07 and '08 W221s do not permit this simultaneous use - that is, the iPhone must either be disconnected, or some other action taken to switch from music play to phone. If some of you with experience could confirm this, or shoot it down, I'd appreciate it.
I am not certain you can use the iPhone nav capabilities as a substitute for a factory nav system (is that why you think you need a GPS antenna?)
- The phone has to be in the cradle in order for it to work, even though the phone is connected via Bluetooth.
- This means that although you can connect up to 4 different phones, they all have to be iPhones as they have to fit in the cradle
- You can achieve the same by having a MP Bluetooth puck and an iPod connector.
- Except for the switching between music and phone mode, which I do not know if it possible without the cradle
I wish the Bluetooth connection would have worked without having the phone in the cradle which would also have enabled to connect other phones than iPhones
I understand that the phone needs to be in the cradle for music playback (as long as the car/the phone do not support BT audio/video streaming) but to me the main idea of BT in the car is that you can keep your phone in your pocket or where ever it is. I was assuming this was possible with the iPhone and the iPhone cradle too (although since iPhone does not support BT SAP, it would soon run out of battery if not in the cradle, specifically the 3G model).
With this implementation one would need multiple BT adapters for different phone models, just like different cradles are needed for different phones. The latter is obvious but for BT HF this it completely stupid. Or do you find any goor reason for this?
My problem is that you can't replace the factory radio to install all my toys. Is anybody knows if there's any adaptor to connect my iphone to the OEM radio ?
Thank you
Thank you
My installation of the Dension Gateway 500 for MOST bus cars is at http://www.benzworld.org/forums/audi...st2376586.html. The D2B installation for your car is MUCH simpler (no changes in the trunk). Also, you will not have song title readout (a limitation of the older COMAND units). You do get track numbers; however, you can select songs, albums, playlists, and artists using the iPod itself, and you can scroll and control volume using the COMAND and steering wheel buttons. Music playback is paused for navigation instructions and phone calls, and resumed after. You also keep your CD changer - something not offered by all iPod integration kits.
Another alternative is to replace the entire COMAND system (and the Bose audio system, voice control, phone system, and CDC) with something like the Pioneer AVIC Z4 or D3, or a Kenwood or Alpine unit. Folks have written up their experience - just search the audio and telematics forum and the specific vehicle forums for their posts.by the brand names.
The only W220 that had a direct plug-in for iPod was the '03 model. It is located on the left side inside the glove compartment, and is a 3.5mm stereo jack.
Oh and any known problem spots with the S that I should look out for would be helpful also (it does have less than 100k ion the clock)
Follow the matrix in the first post to see which of the first seven posts apply. You would be installing an MHI phone system; your car has a MOST fiber optics bus.
Your simple question on "known problem spots" would fill a book - in fact, and Encyclopedia. See http://www.benzworld.org/forums/w220...tart-here.html
Don't be too put off; at 100K, you could have Airmatic problems and could begin to have wear in some steering and front suspension components. The Encyclopedia lists just about every problem folks have - but no one has all of them. The buying guide info in the last post has some info on potential trouble spots. I refer you to that particular forum for the Encyclopedia because it is maintained and more current there.
