Sponsored by: Innova
Don't Have Handsfree Wiring, need part #'s
Old Jul 13, 2008 | 05:12 PM
birjuh's Avatar
2006 ML350
Hi, I have an 06 ML350. The car was an early production model without pre-wiring for the handsfree system. As such, I want to add bluetooth but need more than the puck itself. Does anyone know of all the part numbers needed to do the wiring? I have TeleAid (so it has the mic in the rear-view mirror). But I remember from somewhere that the mirror still would have to be replaced and I wasn't sure why. Thanks for help in advance!
Old Jul 13, 2008 | 11:44 PM
whoover's Avatar
'19 E63S sedan
I think most of what you're looking for is here"
http://phdwebsite.powerpulse.cc/Phon...05-04%20ML.pdf
As you see, there's a lot involved.
Old Jul 14, 2008 | 09:21 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Whoover is correct. However, see also Post #4 at https://mbworld.org/forums/showthrea...7#post2788377; although it applies to model years through '04, the phone system in the ML lagged behind some other models.
I don't have a phone bulletin for an '06, but if the '06 used the same equipment as the '05, then the new "Universal PSE" and the "Cradle eliminator" discussed at Post #4 could save you some money. In addition, if you live in an area having good reception, you may be able to skip the linear compensator and antenna switch, using the newer components.
I'm taking a guess, jumping from the '05 ML information to the '06 ML; so please provide us feedback, especially if I am wrong.
If the '06 ML differs, it probably has an MHI system. Post #5 in the "How To Guide" link deals with that, but again, I do not have the '06 ML phone bulletin to confirm.
In addition, if you truly lacked "pre-wiring" as discussed in Post #1 of the How-To Guide, you would need to add the wiring harnesses. Indeed, MB began eliminating the wiring harnesses for MY 06 in some cars, offering them as an option. However, two other options were required, in addition to pre-wiring: the "handsfree option," which provided the necessary electronics; and either a plug-in cradle, or a Bluetooth puck. Your dealer should be able to tell you specifically whether you have the harnesses in place. He should also be able to refer to the '06 phone bulletin for equipment.
