Sponsored by: Innova
COMMAND CENTER
Old Nov 21, 2008 | 02:53 PM
DANIELPMCGUIRE's Avatar
2004 S430MATIC
COMMAND CENTER
A FEW MONTHS BACK MY COMMAND CENTER STARTED DISPLAYING THE MESSAGE "FLASH FILE DAMAGED, WILL REFORMAT, DO NOT TURN OFF". THE DEALER STATES THAT THE COMMAND CENTER MUST BE COMPLETELY REPLACED @ A COST OF APPROX.$7,000. THIS IS A 2004 S430 MATIC. IF I REPLACE IT, IT IS ONLY COVERED UNDER A 1 YR WARRANTY. MY EXTENDED WARRANTY WILL COVER IT BUT ONLY ONCE. I GUESS I HAVE NO ALTERNATIVE BUT TO REPLACE IT, BUT I AM CONCERNED THAT IT WILL HAPPEN AGAIN. THE COMMAND CENTER CONTROLS ALMOST EVERYTHING. I CHECKED WITH VARIOUS PARTS PLACES BUT THE COMMAND CENTER HAS TO BE SET UP ELECTRONICALLY FOR THE PARTICULAR CAR. ANYBODY WITH ANY EXPERIENCE ON THIS OR ANY SUGGESTIONS?
Old Nov 21, 2008 | 03:22 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
IT SHOULD BE ABLE TO BE REPAIRED. I DON'T THINK YOU WOULD NEED TO REPLACE IT.
IT SHOULD ONLY CONTROL THE TELEMATICS/AUDIO/NAV AND I DON'T THINK IT WOULD NED TO BE SET UP ELECTRONICALLY FOR THE PARTICULAR CAR.
Old Nov 21, 2008 | 05:11 PM
2004 S430MATIC
COMMAND CENTER
DEALER SAYS CAN'T BE REPAIRED. IT HAS A SHORT IN THE SYSTEM. DEALER PUT IT THRU ALL KINDS OF DIAGONOSTIC TESTS.
THE COMMAND CENTER CONTROLS EVERYTHING>THE RADIO SYSTEM, CD,CLOCK, NAVIGATION, MAP. YOU CAN'T EVEN ADJUST THE TIME WITHOUT IT. TO REPLACE IT FOR $7000 FOR ONLY A 4 YEAR CAR & THEN TO ONLY HAVE A 1 YEAR WARRANTY ON IT, SEEMS CRAZY. HOWEVER, WHAT CAN YOU DO?
Old Nov 21, 2008 | 06:59 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
You could investigate something like this: https://mbworld.org/forums/audio-ele...alled-slk.html or http://deverse.com/jbm/2007/09/24/me...ic-d3-install/ or even https://mbworld.org/forums/audio-ele...view-pics.html
Old Nov 22, 2008 | 03:18 PM
Rick SL55's Avatar
2005 SL55 AMG, 1986 Porsche 930S, 1996 Porsche 993tt
search at ebay
