Sponsored by: Innova
Turning of Audio on Comand
Old Feb 7, 2003 | 03:26 AM
Apollo's Avatar
E320 CDI Elegance auto
Hi, have c class comand.
Seems like a silly question, but how do you switch off the CD or radio when playing other than turning off the whole unit.
Old Feb 7, 2003 | 07:26 AM
prenobe's Avatar
Lower the volume ?
Old Feb 7, 2003 | 11:59 AM
jswedberg's Avatar
C32 AMG
The mute button stops the cd and/or turns off the radio.
Old Feb 8, 2003 | 02:41 AM
Apollo's Avatar
Seems a little strange that there is no proper way of doing it.
Old Feb 8, 2003 | 02:41 PM
cone's Avatar
2013 SL 350, ML 350 BT
I can tell you in my 2001 S class if you pressed two times source knob such as cd or radio for example, that source turned off, but in my 2003 S class with comand 2.0 based, you only can turn off telephone so, no other sources. I think it is a very big deficiency. You have all reason
Old Feb 8, 2003 | 09:00 PM
Safet's Avatar
mute button, the speaker with the line going through it
Old Feb 10, 2003 | 01:28 PM
cone's Avatar
I MEAN, "TO TURN OFF" NOT MUTE, FOR EXAMPLE, IF YOU DON´T WANT TO HEAR MUSIC BUT YOU WANT TO HAVE ONLY PHONE IN YOUR COMAND DISPLAY FOR RECEIVE SMS, YOU CAN´T DO IT IN 2.0 COMAND
Old Feb 10, 2003 | 02:40 PM
jswedberg's Avatar
C32 AMG
I guess I don't understand the problem - if you select the phone display, and press mute, the cd/radio will not play but you should still see your sms data.
As far as I can tell "mute" means the same as "pause" for the cd, and is essentially the same as "off" for the radio.
Old Feb 10, 2003 | 03:26 PM
Safet's Avatar
Here's how to do it:
1. Turn off your caps lock,
2. Learn English to better communicate with English speakers.
Old Feb 10, 2003 | 04:23 PM
cone's Avatar
1. I beg your pardon for my caps!
2. I will learn English hard
3. I wonder if you usually read owners manual
Old Feb 10, 2003 | 11:13 PM
Lynn's Avatar
Maybe you should learn cone's native language, jackass.
