Sponsored by: Innova
Navigation wont display streets
Old Jul 26, 2009 | 12:47 AM
hkss618's Avatar
05 E55 AMG, ML320
I just bought a E55 couple days ago and has the 2005.1 DVD disc. Some reason, it is not showing any of the streets that are in my neighborhood plus the main roads. I living in a different county and would not think that could be a factor. My home was built in 1993, same with the neighborhood. There is a new development, built in 2001ish and it is showing on the map. Anyone know why that is occuring? Seems kind of odd to me.
Old Jul 26, 2009 | 09:19 AM
Eddie Knopp's Avatar
2013 E 350, 2012 GLK 350, 2012 C300 4matic
Does it display streets elsewhere ? If so the nav disc is just old - relaize these lag behind significantly. You may be able to go to Navteq and see if you're included in their DB
Old Jul 26, 2009 | 11:03 AM
lkchris's Avatar
'10 CL550, '12 GL550
I bet it displays the street name on the multifunction display between your speedo and tach. You have to switch to that display, of course.
Old Jul 26, 2009 | 04:33 PM
hkss618's Avatar
05 E55 AMG, ML320
basically, once i reached to my neighborhood or any major cross intersections, it shows nothing, basically it becomes a blank screen once i enter Licking County.
Old Aug 1, 2009 | 12:05 AM
smokdu2's Avatar
sl65
I just bought my car last week and am having the same problem. Only about 15 streets show up in my city. The street I live on has houses back into the 1930's but the street doesn't even show up.
Old Aug 1, 2009 | 08:27 PM
lkchris's Avatar
Look for street names on the multifunction display.
Hardly any anywhere are displayed on the COMAND screen.
When you verify the names aren't displayed on the multifunction display, then and only then will you know they aren't on the DVD. NONE of this is a malfunction.
Old Aug 1, 2009 | 09:26 PM
FT Benz's Avatar
2007 E550 4-Matic
Probably a silly suggestion but are you sure your nav is zoomed in all the way to the lowest street level?
Old Aug 1, 2009 | 10:20 PM
smokdu2's Avatar
sl65
no question is stupid, i'm still learning the car and appreciate any help. It is zoomed as far as it can go. After I select a city ,it asks to select a street, when I start to type in my street, the letters to finish the name are grayed out and I can't finish it. When I select list, only 2 streets show for Modesto, Ca that begin with R. I checked the wifes Escalade and there are over 20 streets that begin with R. I guess they didn't put them on the disc.
Old Aug 1, 2009 | 11:20 PM
FT Benz's Avatar
2007 E550 4-Matic
Ah, I misunderstood.... I thought it wasn't displaying on the map which is why I suggested the zoom. That is strange that the disc doesn't list the streets. I know there are threads around that give the latest version information on the Nav DVD. Perhaps eject the disc and see what version you are running. I would think the dealer should take care of that if they have the wrong DVD in there. Good luck!
