Sponsored by: Innova
Comand 2.0 Video In Motion
Old Sep 19, 2009 | 08:00 PM
MW_ATL's Avatar
'02 C230 Coupe (Me) '03 SLK320 6MT (Wife)
I am sure that this has been well covered in the past, but searching didn't give me what I was looking for.
Collective wisdom: What's the best solution for doing video in motion for a D2B Comand system.
What I would like to do is allow video input from an ipod, either RGB or composite video via the dock using one of Apple's adapter cables in order to allow my wife the ability to watch video on long trips (and just for the 'I can do it so I did it' factor).
It is a factory 2003 Comand 2.0 head unit, with the blank TV/Sat button (I actually have the MB part number if that mattered). I am "budget aware" for this project, but not trying to figure the cheapest cost route, more the "best value" route.
Any experience/advice appreciated!
Old Sep 19, 2009 | 08:57 PM
rsatmans's Avatar
None
I use this http://www.navtv.com/product/16/mb20...eShowProduct=1
Old Sep 19, 2009 | 09:07 PM
MW_ATL's Avatar
Thanks. I've looked at that. Did you install yourself....everything doing fine for you? It is the only option I've found out there, just haven't heard much in the way of what people thought.
Old Sep 20, 2009 | 04:50 PM
rsatmans's Avatar
None
Yes, I installed it myself. Took about 2 hours with some aggravation. It is the only unit that I know of that does not require physically sending the nav unit somewhere to activate the blank button. The picture is pretty good...I have an Ipod hooked up with good results. I see you are located in ATL.... I am in Athens if you need some troubleshooting help.
Old Sep 21, 2009 | 10:13 AM
MW_ATL's Avatar
Thanks! I may look for you once I scrape up the cost of the unit. I got to figure out how to get that together without telling the wife how much I'm spending .
Old Sep 21, 2009 | 10:17 AM
rsatmans's Avatar
None
I can't imagine them selling a lot of those. I would call them and see if that is the best they can do on the price.
Old Sep 21, 2009 | 10:53 AM
Badabings's Avatar
2007 E63, ML350
Is there a similar item on the market that would work on a 07 E350? I tried the vehicle selector and NAV-TV doesnt seem to do one for the E350.
Old Sep 21, 2009 | 01:28 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
IF and only if your '07 has DVD display while stationary, you might look at https://mbworld.org/forums/s-class-w...-189-00-a.html. If you cannot display DVD video while stationary, then skip this.
Old Sep 21, 2009 | 02:45 PM
Badabings's Avatar
2007 E63, ML350
I cannot play DVD's at all. Do I need a new Command unit to do so, or is there a work around for that as well?
Old Sep 22, 2009 | 06:38 AM
Skylaw's Avatar
No work-around. Your only choice would be to go to a newer COMAND system at a cost of $4-5K.
