Sponsored by: Innova
COMAND users, please help
Old Mar 16, 2003 | 06:22 PM
Lynn's Avatar
When Steve installed my COMAND, both GPS antennae he had were bad. He sent me another and I have connected it. How do I get it to show me how many satellites it is receiving? I don't have the cd for my region. I have a copy of the CA, NV disc that Steve was using for testing.
I entered the address in Anaheim of someone I knew who used to live there. The COMAND voice tells me that I am "of the area of the digitized roads." Does this mean that it is receiving GPS signals?
Old Mar 16, 2003 | 07:29 PM
awiner's Avatar
2003 CL55 AMG
On mine I hit the "MAP" button and at the top it lists the LAT / LON as well as SAT info.
Old Mar 16, 2003 | 07:52 PM
Lynn's Avatar
That's the problem, Adam. I'm not on the map, I'm over 1000 miles east of it. After fiddling with the buttons and knobs, I got a screen with an arrow showing the direction and distance to the address in Anaheim that I entered. Both are accurate, so I believe that I am receiving signals from the GPS satellites. I guess I'll be buying the map set soon. I found a source that sells the all the NA discs, except Hawaii/Alaska, for $275.
Old Mar 16, 2003 | 09:41 PM
awiner's Avatar
2003 CL55 AMG
Depending on what version of the firmware your COMAND has, you may be able to find out how many SAT's you are receiving. Hold MUTE + 1 + 3 down at the same time for about 5-7 seconds. This should put you into a Diag screen. If it does not try again. When you get to the Diag screen, choose Versions, then infos. On newer COMAND units there will be a line that tells how many SATs you are receiving as seen here :
See, https://mbworld.org/forums/showthrea...ht=COMAND+DIag for more info.
Old Mar 16, 2003 | 09:53 PM
2SYKbenz's's Avatar
When I drive to school I have to use two different discs, If I only have the second disc in then for a few hours it shows me in the middle of a yellow sea for awhile. Then when I approach where the disc is programmed to roads start to appear on the right of the screen. Dont know if that helps at all
Old Mar 16, 2003 | 09:56 PM
Lynn's Avatar
My firmware it too old. It doesn't show than. Is their anyway to update the firmware? If the dealer can do it, I have a service appointment Tuesday.
Old Mar 17, 2003 | 02:12 AM
awiner's Avatar
2003 CL55 AMG
I assume you have the Euro Comand with the Euro firmware ? the dealer can install the new firmware via a CD if there is a newer version avail. than what you have, and you have a US COMAND. If you have a Euro COMAND, I'm not sure what you would lose or gain.
Old Mar 18, 2003 | 10:53 AM
dwang's Avatar
C230K and ML320
Lynn,
From what you are describing, it seems like you are picking up GPS signals... I have the Comand update firmware disc if you need it. It seems like a fairly simple process to upgrade. I didn't have to do it since mine already had the lastest firmware upgrade. Let me know if you want it.
To upgrade:
While the unit is off, slip in the update disc. Then hold down both star and pound keys while powering up the unit (I think you could insert the disc after you do this procedure rather than before). It will display insert update CD and then it will change to another screen which will show you your current bios and the new one you will be replacing it with. The whole process is about 45 minutes and after you're done, the unit will then power down and back up again. It will then ask for your Navi CD.
The new upgrade has the intellispeller feature. Basically, it will blank out or dim any unusable letters when you do a city search so that the next available letter is only one click away. Also, it's rumored that with the update, the Comand draws less power from the battery.
Dave
Old Mar 18, 2003 | 11:56 AM
awiner's Avatar
2003 CL55 AMG
dwang, is your update disc the Euro or US version ? I have the Euro version from a webpage I once found dealing with COMAND. Looking for the US version however.
Old Mar 18, 2003 | 12:08 PM
dwang's Avatar
C230K and ML320
Adam,
Sorry, but it's the Euro Comand version...
Dave
Old Mar 18, 2003 | 01:32 PM
Crankin's Avatar
2000 S500 Brilliant Silver, 1990 BMW 735iL, 1971 Pontiac Trans Am 455 HO, 1976 Pontiac Formula 400
dwang, do you know if there is an update that installs an intellispeller for a 2000 S500 US COMAND?
Old Mar 18, 2003 | 03:46 PM
Richard's Avatar
2004 SL55, 2015 A250d, 2016 GLC250d
BTW, on COMAND 2.0, if holding MUTE+1+3 together doesnt get you into diagnostic mode, select AUX input first, then try it
(AUX input is got by pressing SYS, then twiddling/pressing the right hand knob to select aux input)
R
Old Mar 19, 2003 | 04:32 AM
cone's Avatar
2013 SL 350, ML 350 BT
R
Is there an update disc for 2003 Comand 2.0? Is it the same disc for 16:9 Comand unit?
Regards
Old Mar 19, 2003 | 05:59 PM
Lynn's Avatar
Originally posted by dwang
Lynn,
To upgrade:
Dave
Dave, I would like to have that update disk.
Old Mar 20, 2003 | 07:26 AM
dwang's Avatar
C230K and ML320
Lynn,
Check your PM...
Dave
Old Mar 20, 2003 | 10:09 AM
2SYKbenz's's Avatar
is the euro command a dvd based system or is it cd based like the US one?
Old Mar 20, 2003 | 11:42 AM
Lynn's Avatar
It is cd based. It has a couple of extra features such as RDS.
Old Mar 20, 2003 | 08:12 PM
dragonrt's Avatar
2000 S500 Designo Edition
If we apply the Euro COMAND firmware update to a US COMAND, Does it enable the TV button as well ?
Old Mar 23, 2003 | 09:17 PM
Silver_Lana's Avatar
I wonder if RDS will be enabled if the EURO firmware is used to flash the US COMAND. Perhaps RDS is implemented in hardware?
Any thoughts?
Old Mar 26, 2003 | 10:37 AM
kaneman's Avatar
If someone will send me an ISO image of the disc or the files then I'll try upgrading mine ('02 C32 Comand) and see if that activates RDS.
Old Mar 26, 2003 | 01:43 PM
Any thoughts?
Anyone with any info on this or maybe we can supply the ISO file?
Old Mar 26, 2003 | 02:04 PM
dwang's Avatar
C230K and ML320
Hmm, interesting theory. I only have the Euro Comand ISO upgrade file. I can burn you a copy Silver_Lana. But I have no idea what it does if it's uploaded onto a US spec Comand. I, for one, would not want to take the chance of uploading it and somehow mess up the Comand.... The choice is yours!! Let me know.
Dave
Old Mar 26, 2003 | 03:22 PM
Crankin's Avatar
dwang, not to hijack this thread, but do you know if a MB remote will work on my 2000 S500 comand (2.5)?
Old Mar 26, 2003 | 03:27 PM
dwang's Avatar
C230K and ML320
Sorry, I have no idea. This would be a question for Steve.
Dave
Old Mar 27, 2003 | 03:23 PM
Dave
It wouldnt be going in my COMAND. I have a friend who added the US COMAND unit to his 1999 C280 and he loves to try and tinker with things. If we can get that going, then i can report back with results.
PM me if you are willing to give it a shot.
