Separate amp for am and fm?
The C class has antenna amplifiers. The ones in the coupe can be damaged by water when tint shops try to install the tint from the back of the car with the hatch raised.
Why would anyone want/need separate amps for AM and FM? Makes no sense at all. Why do you ask?
Do newer MBZ's have a separate amps for both am and fm?
Tony
1. Amps usually means audio amps in an audio system. Antenna amps are something else.
2. Where is your thread "Thoughts please?"
I know in ML it has an AM amp in the liftgate and from there I think most/all MB model does has one. This amp require power from the HeadUnit to power up if you change to after market HU you need to wire this line to the power out on the new HU. Most of the time the installer don't know it there and the result is no AM.
Tony
Kal, It's under the audio and electronics section, just scroll down and you'll find it.I just gave this post a bump up to make it easier to find
Thanks Tony. My speakers sound like they are blown in AM mode and when I switch to FM they sound fine,could a bad AM amp be the problem? There is also no static in AM but as the annoucer speaks it's when the speakers sound blown.
Other option is bring it into the dealer, maybe the ground connection at the antenna is loose.
Sorry that all I know.
Tony
