Is my 2006 C230 Sport Pre Wired?
I am trying to find out if my vehicle is pre wired for bluetooth. I already tried talking to my local dealer service advisor but he is too "busy" to answer my question and he wants me to drop off the vehicle and keep it for a full day just to answer my question. Non-sense!!
I read on another thread that someone posted their VIN and someone else was able to answer if the vehicle was prewired. Is there someone that can help me with that?
I can tell that there is at least a black plastic tube going to the centre console. I was able to pop the little cover where the plug goes expecting to see at least a wire there but there is nothing. It is not even a bump, it is flat. Under that little cover.
Thanks!
Thanks!
http://phdwebsite.powerpulse.cc/Phon...0C%20Coupe.pdf
look around page 17; it shows where to look... if you do not have the cables running into the console then you have no prewiring at all.. if you do have the cables then you need the whole completer kit (the UHI, compensator, switch, and contact plate)
You will not need some of the parts that some of the people on ebay sell - ie no linear compensator or antenna splitter is needed because the bluetooth module uses you telephone's antenna. Cost should be under $700 if you install it yourself.
I have no experience doing this install and I got it done in my 2008 CLK350 so I know it can be done by most folks who want to try. I just don't know how similar the install in a C is.
MBAgain
