Sponsored by: Innova
Motorola V60 hands free kit, install?
Old Apr 4, 2003 | 10:12 PM
jersey44's Avatar
2002 C-Class
Unhappy Motorola V60 hands free kit, install?
I have a 2002 C--Class and I just purchased the MB hands free V60 phone kit which I am trying to install myself. I'm STUCK! Where does the PSE module install. I already installed the cradle, but cannot find where to put the module. Can anyone help me? It would be appreciatted. Thanks
Old Apr 5, 2003 | 03:04 AM
dragonrt's Avatar
2000 S500 Designo Edition
Search for the topic "Nokia 6310i". See link below
https://mbworld.org/forums/showthrea...ighlight=6310i
Old Apr 5, 2003 | 01:53 PM
jersey44's Avatar
2002 C-Class
Unhappy
Thanks for the response but still no luck. I followed the instructions but the system still does not recognize the phone. The phone IS a Mercedes Benz phone, so I do not know what the problem is.
Old Apr 6, 2003 | 07:12 AM
rgleason's Avatar
C240 2002
Did you install the necessary fuses if they were'nt already installed, e.g.,
^ N10/2f13 - 5 amp fuse located in the rear SAM (N10/2)
^ N10/2f16* - 7.5 amp fuse located in the rear SAM (N10/2)
^ F34f40* - 7.5 amp fuse located in the interior fuse box (F34)
^ N10/1f44 - 5 amp fuse located in the front SAM (N10/1)
^ N10/1f44 relay located in the front SAM (N10/1)
^ N10/2kf relay located in the rear SAM (N10/2)
* The ETM may show the current rating for fuse F16 and fuse F40 incorrectly. Please check your ETMs and make the following corrections: Fuse F16 is 7.5 amps and fuse F40 is 7.5 amps.
Note: I didn't have to install the relays and didn't.
Also, are you certain that you hooked the fiber optic cables up correctly? You need to tie the phone wiring into the headunit.
Dick Gleason
Old Apr 6, 2003 | 10:27 AM
jersey44's Avatar
2002 C-Class
I will recheck the fuses. I hope that is the problem. The optic cable was already inserted into the radio head. There were two orange wires, one radio in and one phone out, which were inserted into the head when I checked. So lets hope the fuses work.
