2006 C280 Amp Sub install
I'm the proud owner of a 2006 c280 and I love my car!! I have the stock stereo no bose/HK the sound is clean but at higher volume the bass gets a little choppy. I want to install a amp and sub that I have from my last car to add some bottom end and give the little speaker in the doors a brake. I have done a bunch of reading on the install and I'm afraid I have worked myself into a stuper. I have some of the install worked out but I need a couple things cleared up for me.
I have found the way through the firewall for the power cable, right behind the battery so that's taken care of. I have found my way through the cabin of the car and have my cable path worked out all the way to the trunk. I found on this site somewhere that you can tap into the fuse box in the back for a remote wire to turn on the amp, a simple volt meter will help me find that but if someone knows please let me know. The big issue I have is where do I tap into to get the audio signal. I have come to the grips with the fact I'm going to have to tap a speaker wire somewhere as RCA's are out of the question. So my question is where is the easiest place to tap into a speaker wire without taking the dash apart. Any help would be great!
Thank you
So the remote is taken care of and a cleaner install using RCA cables is in my future. But I'm still not clear on where to pick up the speaker wires to tap in the line converter. I really want to avoid popping open the dash and getting at the head unit. Anyone know the location and color for either the front or rear right speaker wires??? After I locate them its all over but and afternoon spent wiring.
Thank for the idea Mertinsvi and TY for any help anyone can offer.
