DIY: New Chrome key upgrade/retrofit.
With the main idea of getting the induction coil and soldering it onto my key without one. Unfortunately, it didn't have the correct induction coil.
I did see it did have a 30pin chip the same dimensions as the nec chip with the numbers F9234. Although I don't see the other larger chips (AMS and what not) on the board. Think it would be worth a try to switch chips?
The reason I ask is that the Mercedes logo fell off from one of my fobs (Version 1), but Version 1 is difficult to find used; Version 2 is a lot easier to find. I just want to take out the circuit board from my original fob (Version 1) and pop it into a new one (Version 2). I don't need to swap the ROM chips or anything.
The old all plastic black smart key and the new facelift chrome key are identical in the fact that they both are made of plastic i guess. The chrome part of the facelift chrome smart key are chromed plastic i guess but i will not say it for sure
So a while back my car randomly wouldn't start. Saw that the Transponder coil was damaged. I eventually got the Rounded Panic version chrome key off of ebay, and had a professional microsolder the chip in.
The key unlocked my doors just fine, but doesn't work on the ignition (nothing happens when I place the key in.)
I tried pressing the buttons to see if I can see an IR signal from y Phone's camera and didn't see any...but I assume there is one if I can unlock/lock the doors.
Maybe a fuse is bad? which fuses would I check? Any help would be great.
EDIT. IR does work with face cam and not back camera
