Sponsored by: Innova
2007 S550 Comand Unit
Old May 15, 2011 | 07:57 PM
LBENZS550's Avatar
S550 2007
Can someone tell me where I can find the aux audio on the comand unit of a 2007 S550? I have video but no audio for my VIM unit.
Old May 16, 2011 | 07:33 AM
cc4469's Avatar
E350CDI S212, MY2011
Hi,
what's the question - how to enable the Aux input (Comand: Audio/Audio/Aux) or where to plug the connector in (glovebox)? If you cannot find a proper connector in your glovebox, check, whether code 518 is installed in your vehicle (Universal Consumer Interface, aka Ipod-Interface). This U.C.I. comes with three different adaptor cables from Germany: one for your Ipod, one for a USB-Connector and one for a 3,5mm Stereo connector).
CC
Old May 16, 2011 | 11:09 AM
Diesel Benz's Avatar
Audio appears at the COMAND connector pins 15 (L), 5(R) and 6 (GND). As above, you may have these occupied by the iPod interface.
Old May 16, 2011 | 01:31 PM
squerly's Avatar
Depends on the day...
I have a 2008 S550 and I've checked in the glovebox. nada... Where should I be looking?
Old May 16, 2011 | 04:53 PM
It should be at the left side of the glove box.
Old May 17, 2011 | 07:32 AM
squerly's Avatar
LOL, not on mine! On the left side of the box is a small air vent with an adjustable air flow cover. With the exception of a small light, there is nothing else in the box.
Old May 18, 2011 | 03:44 PM
jbondox's Avatar
beater with a heater
you can order the parts from MB and add them or you can cal midcity and buy 3 terminated RCA plugs and put them in the harness as mentioned by diesel. more than likely if yours has not have the comand update you should have it performed. it will have the video word between phone and system on the top of the screen
earlier vehicles did not have them enabled from the factory
Old May 18, 2011 | 06:39 PM
LBENZS550's Avatar
S550 2007
Hi JBONDOX
Do you happen to the parts number? I called the dealer and he has no clue on what I'm talkng about. He says I need the part numbers. He provided with a cable harness and I really dont think that does the trick.
Old May 19, 2011 | 05:15 PM
jbondox's Avatar
I will look into it Saturday for you. other wise midcity 312.421.1114...ask for TJ
Old May 20, 2011 | 11:56 AM
LBENZS550's Avatar
S550 2007
I will make a call to TJ at midcity but if you can lookup the MB part number Saturday it would be greatly appreciated. I tried several online sellers and keep gettting the wrong part. So at least if I go with MB I can't go wrong.
Old May 24, 2011 | 09:42 AM
jbondox's Avatar
sorry haven't had time yet
Old May 25, 2011 | 02:45 PM
LBENZS550's Avatar
S550 2007
its completely understandable, when time permit
thx again
Old May 25, 2011 | 04:41 PM
jbondox's Avatar
well I looked at it on EPC NET, the MB parts catalog that they use and couldn't find it. I will find a vehicle with it in already and run the VIN to see if it comes up. I think honestly the Midcity RCA jacks will be the cheapest route to go.
Old May 25, 2011 | 04:53 PM
LBENZS550's Avatar
S550 2007
thanks for your help. I will contact MC and get the RCA jack.
again thx
Old May 26, 2011 | 04:08 PM
jbondox's Avatar
i came up with these numbers but am not to sure if it is the right stuff
221-540-77-34 aux cable $26.13
221-440-88-36 aux cable $10.04
221-545-02-43 a/v bracket $3.31
all special order....
again I am not to sure
Old May 27, 2011 | 12:10 PM
LBENZS550's Avatar
S550 2007
thanks for researching this information for me. im going to check into this today
i will let you knw how it goes
Old Jun 15, 2011 | 05:56 PM
LBENZS550's Avatar
S550 2007
Diesel do you happen to know what the part number for the harness is?
