Sponsored by: Innova
hooking up an Apple iPod
Old Jun 1, 2003 | 05:07 PM
lucycat's Avatar
'02 BMW M3 convertible
Any suggestions as to how one might hook up an Apple iPod (basically an MP3 player) to play through the speakers of an MB ?
There are devices that plug into cassette players and others that use FM signals, but I was hoping for something better (and somewhere I thought I heard that MB has some way of directly connecting) ?
Thanks!
Old Jun 2, 2003 | 12:34 AM
E55MKB's Avatar
96 P993T, 00 E55, 09 SL63
Ipod hookup
If you have MB with Comand 2.0 then it would have aux input jack inside the glove compartment which can be easily connected to the output jack of the Ipod.
Old Jun 3, 2003 | 11:21 AM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
Re: hooking up an Apple iPod
Thanks!
I don't think you will be able to directly connect it to a factory MB system without some wiring. Try calling Ofer at Galaxy Auto Sound in Northridge at (818) 700-0440 and tell him that Jimmy sent you. He might be able to help as he does a lot of custom installs and systems...Good luck.
Old Jun 3, 2003 | 01:55 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Re: Ipod hookup
Not all cars with COMAND 2.0 include the jack in the glove box. Some require its addition.
-s-
Old Jun 8, 2003 | 06:12 PM
John_Collins's Avatar
1999 SL 600 Sport Model
Good information if mine had the Comand System, but I have a 99 SL on which it was never offered.
However, I had no use for the factory phone so I removed it and have wondered if there were a way to locate the audio-in wires in the phone cabling and tap an iPod into them. Then, in theory, setting the receiver to phone could allow the iPod to play.
I know it's a stretch, but I'd attempt it if I could find specs on the cables.
Anyone have a connector diagram?
Old Jun 11, 2003 | 01:35 AM
fus10n's Avatar
c-klase
look up a product called iRock @ http://www.myirock.com
put it in the glove box and forget about it..
Old Jun 12, 2003 | 06:37 PM
Wolfman's Avatar
Super Moderator
Agree with that. Also check on the Belkin which is smaller.
I also believe that the phone is a Mono input only, so sound quality would be significantly inferior to the radio transmitter option.
Wolfman
Old Jun 12, 2003 | 08:03 PM
Wolfman
Mono. Of course you're right. Being an R129 SL I have no glove box, but I'll work it out. Griffin Technology just released a new similar unit that may be the best of the bunch. www.griffintech.com
Old Jun 12, 2003 | 08:46 PM
scorchie's Avatar
You have the place where the phone system normally goes. The iPod and modulator should fit in there without a problem. And it even locks.
-s-
