left indicator causes thumping in speakers
Hello,
Can someone please help I have a clk200(w280) coupe and when you turn the left indicator on there is a thumping in the speakers in time with the indicator, does not do it when indicating right, there is engine noise coming through speakers as well. I suspect it is a bad earth somewhere,both lh indicators seam normal brightness, have checked and cleaned the earth for lhf and rear indicators. can anyone help with this.
Cheers
Cheers
bad ground for sure or a damaged audio component
If you are getting the engine noise coming through the system with acceleration then i would think their would be an amp, and the ground potential between the radio and amp is way off. hate chasing these, but having a wiring diagram helps.
