Sponsored by: Innova
AudioStreaming on E Coupe
Old Jan 29, 2012 | 06:58 AM
Joschelito's Avatar
2012 E350 CDI Coupe
Hello everybody!!
I Picked up my 2012 E Coupe with Audio 20 about 25 days ago, and I got very angry when I saw that it didn't have neither USB and Bluetooth Audiostreaming.
I went into the Engineering Hidden Menu in the Audio 20 (Red Phone+1+#) and there's an option which says Ext Players.
If you go into it, there are 2 submenus. one says UCI (I suppose it's the universal media interface) and the other is Bluetooth Audio.
If you go into that menu, there is an option called Bluetooth Audio Feature Set 2, which is set in "OFF".
If y click in it and put it in On, it makes no difference, and if I restart the Audio 20, It goes back to OFF position.
Does anybody know why is it OFF? and how could I enable that function?? It'd be very useful for me to connect the iPhone.
Thanks very much
Old Feb 21, 2012 | 12:17 AM
dsayed's Avatar
2010 E550 coupe
No experience with Audio 20 sorry. Did you try resetting your system after you made the change (different to turning it off)?
Old Feb 21, 2012 | 03:30 PM
Joschelito's Avatar
2012 E350 CDI Coupe
i've tried rebooting the system by turning off and onn the Audio 20, but when I do this the "Bluetooth Audio Feature" is OFF again.
How can I reset the system?? I've read I can do this by removing the fuse. which one and where is it??
Thanks for the help
Old Feb 22, 2012 | 12:57 AM
dsayed's Avatar
2010 E550 coupe
Don't know sorry. I'm actually driving a C class with an Audio 20 system in it at the moment. I went into Engineering Mode but did not see a reset option like on the high units.
Old Feb 22, 2012 | 01:55 PM
Joschelito's Avatar
2012 E350 CDI Coupe
I looked for it, but there isn't a reset option, like on the Command.
I'm still searching in the internet for any way to do it
Old May 2, 2015 | 02:14 PM
qska's Avatar
E350
3 years later, same problem...
Hi,
I have the exact same issue - W212 E350 manufactured in 2009, first registered in 2010 in the UK. With Audio 20 radio.
I can enable the Bluetooth Audio Feature Set2, but this does no difference to the phone - my Galaxy S5 shows only "Call Audio" for MB Audio Bluetooth device.
For my old car with a Parrot minikit I had both Call Audio and Media Audio profiles visible in my phone...
Help?
Old May 3, 2015 | 06:56 PM
jbondox's Avatar
beater with a heater
I thought that there was a comand update disk for this. if a mb tech on here can look through their update discs at work maybe you will get lucky and this will solve your problem.
Old May 3, 2015 | 07:01 PM
jbondox's Avatar
the last record i have in my pc is disc 166 827 04 59
