Sponsored by: Innova
Sirius retrofit
Old Jul 14, 2003 | 02:51 PM
Enze6997's Avatar
E350 Coupe (2010)
Sirius retrofit
I was at the C Spot Drive party on saturday at Fedex Field in DC and I noticed that they were using the good ole Tape deck head unit that comes in all of the C class 02+ for satellite radio reception. Its the Exact same head unit but I assume they just modded the software to allow for the text display to show the song title and station name.
Anyone thought of a way to retro fit this? will the 04 C class have sirius in them? if so I would assume a command software upgrade would do the trick for it being an option.
Ensey
Old Jul 14, 2003 | 03:45 PM
Lynn's Avatar
The 04's are supposed to get Sirius capability at some point, but not necessarily at the start of the model year. I doubt that a simple software update will enable Sirius reception in existing cars. A Sirius receiver will be needed, and while the headunit may look the same, I think it will need to be changed.
Old Jul 16, 2003 | 09:51 AM
Enze6997's Avatar
E350 Coupe (2010)
I would think that all you would need is a reciever and the proper pin out to the back of the head unit and to just update the software to accomidate. Its just taking in a either FM signal or a digital signal similar to the db2 fibre off the cd changer.
