Sponsored by: Innova
01 CL55 Audio issue
Old Aug 8, 2012 | 02:32 PM
mbenzCL55's Avatar
2001 CL55 AMG
01 CL55 Audio issue
As of 2 days ago, my audio has been not working, I get the display screen and the navigation works and can switch through radio stations select cassette etc, but don't get audio. The audio is amazing when it works (stock) but randomly started going out recently. I have to give it a smack and turn it off\on to get it to work, I'm thinking an audio input cable is loose in the back? Any suggestions?
Old Aug 8, 2012 | 02:42 PM
awiner's Avatar
2003 CL55 AMG
Sounds like something is amiss in the fiber ring (or the amp is starting to become flaky). I would suggest having it diagnosed with Mercedes Star Diagnostics.
Old Aug 8, 2012 | 10:06 PM
alx's Avatar
alx
You need das to diag the optical ring. Alternatively you can remove the head unit and check the connectors in the back. Your particular setup is prone to unplugging in the back as the secure connectors age and the locks break off.
