Sponsored by: Innova
Help? Need to replace Broken Radio
Old Jul 21, 2003 | 10:59 AM
rsmcmahon's Avatar
CLK, ML320, 400E, 400SE
Question Help? Need to replace Broken Radio
I have a 92 400se with FM radio problems. When I select the FM radio channels, only the right side audio works. If I select CD, AM or Tape the radio audio works fine.
I have had the Bose 7 Channel amp replaced $$$, so I'm wanting to stay with a MB radio.
Assuming the radio needs replacing, does anyone know what my opions are? I have seen several MB replacement radios on Ebay, but most are advertised to work with MB year models 94-00 etc...
Any help in the matter would greatly be appreciated!
Thanks,
Russell
Old Jul 21, 2003 | 03:43 PM
Limited Edition 190E's Avatar
2005 CL65 AMG
You will have to get a wiring harness to use those stereo's I think you have a Becker 1432 which is a two-peice radio and has a receiver in the trunk. It may be cheaper to find another BE1432 deck instead.
