Samsung Galaxy s3/sIII Bluetooth periodic disconnection
C350 Sport Sedan
I got my 2013 C350 2 weeks ago. I could pair my Verizon S3 (ICS) and my wife's iPhone 4S with my car easily and transfer all my contacts, and all the phone calls through my s3 have a really good quality, although I wasn't able to get my text msgs. But the main problem is that my s3 keeps disconnecting and reconnecting every 2 minutes, and when I'm in the middle of a phone call suddenly I lose connection and I have to wait for re connection. My car's Audio 20 "Reception Volume" and "Transmission Volume" are set to the optimal recommended settings (which is 0 based on what I found on mbusa-mobile.com). What should I do to get rid of the disconnections?
P.S I don't have this problem when I connect the iPhone 4S, it's only with my S3!
Samsung S3
I've just upgraded (or I thought I had!) from a Blackberry to a Samsung S3. I finally figured out how to pair it but my E350 doesn't receive text messages whereas the Blackberry worked great. Can anyone help me? Also each time I turn the engine on I get notification of messages four times within the first couple of minutes of driving, even though I have no new messages. I'm thinking that I should have stayed with the Blackberry.
Check out this thread.In it I refer to a bluetooth problem I had with my Samsung Droid Charge and the solution I...and another poster...discovered.It just might help in your case.
https://mbworld.org/forums/e-class-w...2011-e350.html
