Sponsored by: Innova
HELP!! Command Audio interface mod
Old Jul 29, 2003 | 10:41 AM
]_ us ]-['s Avatar
I have been searching around and cannot find any info on this box and hope some of you can help. Here is what I know for sure.
1. A company out of Germany has made a replacement module for the factory amplifier in Mercedes cars with Command systems. This unit replaces the factory bose amp and gives you RCA audio outputs and inputs ...Front Rear and non fading outputs and L + R inputs. The outputs are not equalized anymore so this is the aftermarket solution we have all been looking for.
2. I own one! But I bought it for a pretty penny and the company I bought it from removed all idications of where it came from.
3. it plugs into the fiber bus to get its signal
4. My sound system sounds incredable!!!
I think the company or the box is called IMOX or something.
This is truely the answer and I want to purchase more of them for my other cars and my friends but I don't want to pay the high price these guys are asking for it (3500USD)
Any insight would be sweet
Old Jul 29, 2003 | 11:41 AM
NightSea's Avatar
S600L/SL55
maybe....
Maybe
it is http://www.linkmeup.com .
Old Jul 29, 2003 | 11:42 AM
]_ us ]-['s Avatar
nope
Old Jul 29, 2003 | 02:07 PM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
I can get those...at a way beter price as well...I have had one in my hands before and yes - it IS the solution for who ever is upset with Bose quality (although a simple sub can do a lot in combination with Bose as well).
greetingz,
Old Jul 29, 2003 | 02:20 PM
rgiorgio's Avatar
CLK, ML, GL
I am also interested. Can't find anything under IMOX. Is there a pic or specs?
Old Jul 29, 2003 | 05:27 PM
]_ us ]-['s Avatar
This is all I know...I will try and do some more research on this but I had hoped someone had seen it.
Understand this is not some hokey adapter. It takes place of the amplifier and connects via the fiber optic bus. It gives you auxillary input and 20-20k fading and non fading outputs. It is the answer!!
imox was just a guess. Thought I overheard this name when I was having the installation done. Either way it is not a $3500.00 piece,
Old Jul 29, 2003 | 07:05 PM
rgiorgio's Avatar
CLK, ML, GL
See what you can find out. I am in the audio industry. I might be able to help out if I can get some more info. I need that piece like yesterday and know a few other people that could use it also. Right now the only answer is Nav-TV.
Old Jul 29, 2003 | 08:00 PM
dtkw's Avatar
1986 560SEL, 97 BMW 740iL
rgiorgio, is that your business or you know where to get stuffs. I am looking for fiber optic wiring for headunit to CD changer and fiber optic wiring for headunit to cell phone in my 95 S500 coupe. Where can I get those?
Old Jul 30, 2003 | 02:34 AM
MBenzNL's Avatar
some slow@$$diesels
At the dealer...isn't even that expensive...
greetingz,
Old Jul 30, 2003 | 06:25 AM
]_ us ]-['s Avatar
This unit is available from a company in Bellevue WA...Innovative Audio 425 885 2814...Maybe someone other than me can get info out of them...They know I am a laydown!!
Too much $ and not enough Time...
Old Aug 1, 2003 | 06:29 AM
]_ us ]-['s Avatar
I have found it...The company is called Domino Mfg. they build the oem amplifiers and such for mercedes...The only US distributer is Innovative Audio in Bellevue WA (425) 885 - 2814 speak with Brian Ellis.
As for the box it is called CRIOS Here is the link...Who is the MAN.......
http://216.239.39.104/translate_c?hl...8%26oe%3DUTF-8
Old Aug 1, 2003 | 06:35 AM
]_ us ]-['s Avatar
This unit is really designed to give you the ability to add DVD but it can be the replacement for your amplifier. and it becomes your processor... You replace the Mercedes AMP with This box and you can install any aftermarket amplifiers you want with no hoaky siznit......
Again...who is the man...if you want to send me gifts thats ok...
Old Aug 1, 2003 | 11:10 AM
R4ND0M_AX3's Avatar
C230
How much $$$?
If you replace the BOSE amp do you still have access to the surround modes from the head unit (Driver, Speech, Ambient, none)?
Will new stuff show up for the head unit to control?
Can you use this WITH your bose amp just for the aux inputs?
Old Aug 1, 2003 | 12:12 PM
NightSea's Avatar
S600L/SL55
M.O.S.T.
As I understand,
some new models of MB use M.O.S.T instead of D2B ring system.
(for example, 2003 E class )
Old Aug 1, 2003 | 12:24 PM
R4ND0M_AX3's Avatar
C230
Yes, MOST is the newest stuff.
