UCI USB cable + 30-pin (or lightning cable) for iPhone
I have a 2012 R350, with IPOD integration kit, and the UCI cable which has an AUX and 30pin connector. Then I found out there is an UCI USB cable.
Is anyone doing the following?
glove box <-> UCI USB cable <-> Apple 30pin cable (or lighning cable) <-> iPhone4 (iPhone5) ?
Would this setup charge the phone AND allow steering wheel/COMAND control/display of the iPhone?
Thanks in advance.
Don't know if this helps you or not...
This helps, thanks!
hope you won't mind a few more questions
- Can I ask if this setup charges your phone too?
- Does the COMAND control work? (you mention steering wheel)
- I am surprised to see that COMAND does not display song name.
Have you used the UCI iPod (not USB) cable for your iPhone? (I used to, and song name displays properly on COMAND, as expected).
Thanks again!
- yes, my phone charges
- steering wheel controls work fine - but only steering wheel controls do. I can't advance songs by the dash unit.
- dash unit does not show any song info when connected to the iphone, only the display inside the speedo shows song name. Wish it was more sophisticated... but mine is also a few years old - maybe the new ones do.
I bought a cable off ebay, and unfortunately the car just complains about 'incompatible device'. Ended up getting using the OEM 30-pin cable + Apple lightning adapter, which work very well together (though not as clean as a single cable).
