Sponsored by: Innova
Adding sat radio
Old Apr 6, 2013 | 01:58 PM
mrbobby's Avatar
2003 S500 4Matic (SOLD) + 2004 S55 (SOLD) 2005 CLK 500 Cabriolet 2008 S 450
Adding sat radio
Can anyone tell me just what is required to add sat radio to my 2004 S55? Are the parts readily available?
Old Apr 8, 2013 | 07:59 AM
mrbobby's Avatar
BUMP
Old Apr 9, 2013 | 07:19 AM
mrbobby's Avatar
41 looks and no comments. Is there no one that has the answer?
Old Apr 10, 2013 | 08:18 AM
mrbobby's Avatar
Nobody knows?
Old Apr 10, 2013 | 12:44 PM
City Rat's Avatar
Veteran: Army
Currently: 2019 E450 AWD, Previous: 2002 CLK55 Cab
This might be helpful to you. Good luck.
http://www.benzworld.org/forums/c219...-question.html
Old Apr 11, 2013 | 09:32 AM
mrbobby's Avatar
Thanks for the help.
Old Apr 11, 2013 | 09:57 AM
grane's Avatar
GLK350, SL63 AMG
Do you have an AUX input?
If you search on my name, I described how the techs installed my upgraded SXM Sportster in my G500 in another thread. It uses AUX rather than the FM radio and the sound is excellent. SXM recently upgraded their signal to a Dolby system that hides a multichannel higher FR in their signal that allow it to be decoded into multichannel. BTW SXM says that the AUX interface give better sound than the FM for reasons that are obvious especially if you are in an area with lots of FM stations.
Briefly they tapped into the 12v source behind the Comand system and threaded the antennae through the firewall wiring interface. It is placed under the vents on the front hood. I can unplug the AUX cable if I listen from an iPOD, etc.
I got the reconned unit for free since my wife has a trial in her 2013 GLK. The service person at SXM was in Canada BTW. (Regular CS sucks) My wife is from Toronto BTW. I'll send you a PM when I get a chance if you wish.
Old Apr 21, 2013 | 06:38 PM
grane's Avatar
GLK350, SL63 AMG
Update/Correction
Now: The Antenna disk/puck is placed on TOP of the hood just in front of the windscreen. The shop moved it when I came in with an unrelated issue.
BTW MBUSA now requires all 4 springs on the 463s to be replaced even if one is defective. If you are under warranty MAKE SURE your service writer understands this and make sure ALL of them are replaced on MBUSAs warranty. There is no Service Department Recall, Bulletin or TSB etc.
These instructions are issued through the Parts Department. Thus, the PD will not release say a front pair of springs to the tech even if one only is defective unless you choose to replace all 4. If you do not have them all replaced, and pay them to replace all 4, even though the WIS instructions and techs are trained to replace them in pairs only, the dealer will note this on the repair order as a "refusal to perform recommended service" . They will not put the 4 spring requirement on the repair order in writing! Consider not signing such a repair order; just pay for the A service or whatever you requested.
Old Apr 24, 2013 | 09:30 AM
jbondox's Avatar
beater with a heater
we usually add the factory tuner and turn it on via the SDS. we utilize an aftermarket antenna mounted under the hood. did many in the past, but since the new OPTI-1 came out, we just replace the antique radio with a more modern aftermarket radio.
Old Apr 24, 2013 | 10:28 AM
mrbobby's Avatar
And what does that usually cost?
Old Apr 25, 2013 | 09:21 AM
jbondox's Avatar
Depends on the radio used... $1500 to $2400 to unlimited
