Sponsored by: Innova
SWI-CAN2 Stopped Working
Old Jul 29, 2013 | 03:09 PM
Scott Simoncic's Avatar
2001 CLK55 AMG
Hello Everyone,
I have a w208, I've had a PAC SWI-CAN2 connected to a PAC-SWI-JACK for my JVC in-dash, and it's been working for quite some time. I pulled everything out this weekend to install a sub, now, I'm very well versed in electronics, I do technology integration for a living, so this was a fairly routine procedure for me. Everything went back together, and would not turn on. After a while I diagnosed that the SWI-CAN2 was not giving the remote-on signal, so I checked the fuse, it was fine, checked power to the unit with a multi-meter, +14.4v... Checked the connections at the CAN-BUS wiring, everything was fine there, checked ground, ground was ok (Everything is soldered)... I then checked the LED on the SWI-CAN2, nothing.... Has anyone had this issue before? Where it just fails? I bought it on ebay used, so warranty would be expired. Any suggestions? I'm thinking of opening the unit and looking for anything burnt.
Old Aug 2, 2013 | 06:40 AM
jbondox's Avatar
beater with a heater
Or just replace it. Check power again to the swi can, as they are pretty fool proof, maybe the wire came undone.
Old Aug 5, 2013 | 07:31 PM
2001 CLK55 AMG
So, I'd wrapped both boxes in fabric tape to keep them from tapping against something behind the dash and making noise, in unplugging everything, I swapped the harnesses (they fit each other) so, I had the harness from the swi-jack in the swi-can2 and vise-versa, swapped back, good to go.
