No expensive Upgrade Analogic Tv Turner to DVB-T one
Hi , I'm a new member .
I live in Italy :thumbsup: I'm sorry my english :crybaby2:!
There are more than two years in the Italian television turned to DVB-T
My CLK 55 AMG MY2004 has the analog tv turner and therefore I can not see mor TV aboard!
This is the Comand
This is the TV tuner of my Comand 2.0 dx II series .
As you can see I have the AV ports and will like to use this M44 DVB -T tuner .
Well , I think that I should get me before 4 FAKRA adapters for use CLK antennas and insert DVB-T tuner output in Mercedes TV Tuner AV Port.
Now I have two problems:
a) is that my AV is not enabled!!
b) I will like to see tv on motion!!
Yes I know it!! I have to use the Star Diagnose!!!
Do you know any other system to enable the av and watch TV on the move?
I also thought about taking power by the power of analog TV tuner but I wish only turning on it when it is selected. If I connect the dvb-t to direct Power source..It is no a good Idea..
So ... I need to know what is the analogic TV Turner cable turning on it in order to connect a relay comanding the DVB-T Tuner power source.
What do you think about??
Where can I read something about TV Tuner connections and pin schemes?
The Tv Tuner is BECKER BE7032 ECE A2408200597 Analog
This is the Comand
