CD changer
theres a little screw (T-20, i think) holding the bracket in place at the top of the glovebox. its on the right side of the changer... if you feel around you'll find it. unscrew this screw (it's a bit of a PITA as there's not a lot or room to work with) and the bracket and changer will slide to the right and you'll be able to pull it out. there's a power cable and a fiber cable that will need to be detached. you'll also need to get behind the radio and take the changer FO cable out of the loop.
is the job hard ?
http://www.dawgbytes.com/mercedes/tutorial.pdf
good luck!
