GPS Tracker and Keyless Go
Given that my car will have keyless go, I'm a little worried that 2 RF devices both potentially on the same frequency band would interfere with each other. I hope the designers have considered this and developed compatible protocols, but wondered if anyone here had any experience?
Thanks!
Dave.
i actually just googled to see if anyone had this exact issue.
I have just had a tracker installed in my car and am having problems with the keyless go system.
If I put the key slightly away from the car it all works fine, but if it is close to the car the car won't open at all.
So it does look like it can cause an issue, I will have to get the tracker disconnected to test 100% but i am about 98% sure that is what is causing the issue.
If you talk to comand.co.uk (near you in UK ...) they can check the frequency of the Keyless Go and of the CAT5 trackers they can fit. (Well, i'll do it ....)
EU frequency for KG is different to USA frequency
Richard
