Sponsored by: Innova
Adding AUX input or RCA jacks in r230
Old May 18, 2015 | 09:11 AM
2004r230's Avatar
R230 350 2004
Hi guys, need some advice regarding my R230.
It has this Command system:
http://www.ebay.com/itm/2003-2004-EC...-/271872692165
with the Bose speaker set
which in todays age is seriously limited re: bluetooth integration.
Basically what I would like to do it find a way to get an AUX input setup, then plus one of these into it
http://www.amazon.co.uk/Kinivo-BTC450-Bluetooth-Hands-Free-input/dp/B009NLTW60/ref=sr_1_3?ie=UTF8&qid=1431954611&sr=8-3&keywords=aux+input+bluetooth http://www.amazon.co.uk/Kinivo-BTC450-Bluetooth-Hands-Free-input/dp/B009NLTW60/ref=sr_1_3?ie=UTF8&qid=1431954611&sr=8-3&keywords=aux+input+bluetooth
. I was thinking of removing the cd changer and adding it that way. Unfortunately my SL wasnt blessed with a AUX input in the glovebox.
There is a very good post on here about removing the cd changer but before I go taking everything apart, im just wondering if im missing a simpler solution?
Has anyone else been in the same situation?
Old May 19, 2015 | 03:30 PM
Richard's Avatar
2004 SL55, 2015 A250d, 2016 GLC250d
You could change it to COMAND which has an AUX input
R
Old May 19, 2015 | 03:49 PM
2004r230's Avatar
R230 350 2004
R
I could but I decided to go with a MCAR https://www.commandonline.co.uk/mcar_umi.html, will get it fitted hopefully in the next couple weeks, the unit does everything I need to do whilst keeping an OEM look.
Old May 19, 2015 | 05:18 PM
Richard's Avatar
Unless your SL is model year 2005 - 2008 then mcar won't work
Richard
Old May 19, 2015 | 05:42 PM
2004r230's Avatar
R230 350 2004
Richard
It's an 04 with Audio 20, I contacted the firm CommandOnline in Surrey apparently it'll work.
Old May 19, 2015 | 06:49 PM
jbondox's Avatar
beater with a heater
it shouldn't, yours is d2b not most. If you pull the changer and have this
Then no.
Old May 19, 2015 | 06:50 PM
jbondox's Avatar
the pic of the comand you posted in the first post was a d2b comand
Old May 20, 2015 | 01:40 AM
Richard's Avatar
If the car had and audio 20, that would. But your picture was not an audio 20. I assume comandonline assumed you had an audio 20 if you said you did. The switch over between technology was from June 04 build.
Model Year isn't really used in UK like it is in USA. It's a shame because its a useful differentiator.
Richard
Old May 22, 2015 | 04:29 PM
2004r230's Avatar
R230 350 2004
Richard
Sincerely, thank you. You saved me a massive round trip. I don't know where I got the idea that my head unit was Audio 20.
So now I know its d2b and the only option is the Denison Gateway Lite which isn't exactly what I want.
I think in the end I'll just have to remove everything and put a new amp speakers and head unit in. which is a pity.
Thanks again for your input, I was planning to make about a 16 hour round trip to Surrey!
Old May 23, 2015 | 08:35 PM
jbondox's Avatar
I have done quite a few of the aftermarket retro's before, and it isn't too bad of a task, not cheap either if you use quality components. You can do it pretty much all Alpine and be very happy with it. A single 5 channel PDX amp and type R components for the front door or higher end and bi-amp. rears are wired mono and and you can un-mono them and run them off the aftermarket radio, sub will need the voicecoil wired in series if you re-use the factory sub.
Old Nov 16, 2021 | 02:23 PM
2old2stop's Avatar
SL500
New Solution
Does anyone have a modern replacement for the 2004 R230 Command system?
I have a US model R230 SL500 and I am having trouble finding a retrofit Android Auto, preferably v11, for my beautiful car. I have a Bose speaker system. I don't know if it makes a difference but I do have the Designo interior.
